AC 200 hard starting |
Post Reply |
rodnil
Silver Level Joined: 15 Sep 2009 Location: illinois Points: 241 |
Posted: 26 Jan 2021 at 8:06pm |
I know it is winter and low temps make them start hard. But my 200 is hard starting in warm temps. I have new cables from Agco and two new high capacity batteries and even with jumper cables from my truck it requires several shots of either and several tries to get it fire off. Any ideas or thoughts ?
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7190 |
Any smoke coming out of the exhaust as you crank it? If so, what color? Could be low compression, could be a fuel delivery issue. Have the air filter and fuel filter been replaced recently? How is fuel flow to the pump? In the winter time (or below 40 degrees) DEFINITELY plug it in or use the manifold heater!
rodnil
No smoke. All filters were changed late summer. No block heater , why ?, I don't know.
DSeries4
No smoke while cranking indicates no fuel getting into the cylinders. Pump might be getting weak.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4605 |
My XT did the same thing. After checking fuel flow to the filter, then to the pump, off it went to Ed where he did a rebuild. Starts and runs great now.
MACK
How fast does it spin engine ? Could be bad starter plus inj. pump needs rebuilt and timing restarted. MACK
rodnil
Mack; not a fast spin. It's like having low charged batteries.
MACK
It takes about 800 RPMs to build enough heat to fire diesel. MACK
Orange Level Access Joined: 12 Sep 2009 Points: 19360 |
My first guess is you have a Lucas brand starter and it is performing at half-speed. Not saying this is the whole problem, but the engine has to spin at least 200 RPM steady for the injection pump to even deliver fuel.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4754 |
Like said above, it is cranking super slow, so my first move would be starter, I think the gear reduction for a 6080 fits and is readily available? Make it crank fast first, then worry about if it needs pump work, which it still might.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7909 |
Nothing like a fresh pump job (+ injectors)
CDN 400
Bronze Level Access Joined: 05 Apr 2014 Location: On. Canada Points: 57 |
Especially when Ed does it
rodnil
Thanks for the info guys. I'll start with the starter . If that's not the answer I'll send the injector pump to Ed. He rebuilt my injector on my 220. Will not be able to work on it tomorrow as I'm off to Weatherford, Tx tomorrow early AM. I'll be hauling a new Ford 450 pickup to a new customer . Be back in 3 days if all goes well and I'll get to work on the tractor then.
Post Reply | |
