AC 190xt has started to run rough and die
whizone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Topic: AC 190xt has started to run rough and die
    Posted: 30 Apr 2018 at 10:15am
Guys my tractor went from running and idling great to starting rough and dying after 3-5 minutes. This tractor had setup for years and I just got it. I setup an auxiliary diesel fuel tank and pumped and primed everything from the tank to the injectors. I am sure it’s getting fuel to the pump (broke the line loose).  When it dies its acting as if its starving for fuel. You guys have any ideas in terms of what the problem could be as it was running good at first?  It’s a 190XT and uses the Roosa Master DBGFC 631-31AF pump. Thanks for all your help! Love this old tractor and will see it come back to life somehow!
bradley6874 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 11:01am
Next time it dies on the side pump is the timing window held on by 2 screws loosen them up let the pressure out and start it back up if it starts right up it's time to overhaul the pump get up with an expert ( injpumpEd ) on here you won't be sorry may want to let him do the injectors as well then the fuel system is good for next 30 years
Edited by bradley6874 - 30 Apr 2018 at 11:21am
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 5:45am
Good advice above. Been there and done that. Governor ring has deteriorated and is blocking the return line and building pressure inside the pump. Relieve the pressure and it will start right back up.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2018 at 7:53am
Yep, these pumps don't like being brought out of retirement without freshening them up. Sits for years, then suddenly asked to work again, the flex ring almost instantly begins breaking apart. The other thing is this tractor may have been parked all those years ago simply because the pump was in need of servicing and they just didn't think it was worth it. So many places charge 1000-1500 to rebuild these old DB Roosa pumps, and in my shop they are typically half that. Now, there is an occasional cam ring, head & rotor, or housing needing replaced, but I keep lots of good used parts for that reason. To keep my customers' costs down. I am in business to make money and survive, but I've never expected to get rich doing this lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2018 at 4:31pm
Thanks to everyone for the help..  with this forum and all the great contributors the old tractor may once again run the fields.. :)  Thanks again for all the insights, you fellows are awesome..  TX.
plshelpme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plshelpme Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 10:09am
Hey Ed will you rebuild my 190xt pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 12:46pm
I can if you aren't in a big hurry lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plshelpme Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 3:14pm
Well i'm not in a real big hurry but I need to know how long it would take...Thanks... Greg
AndrewMandel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewMandel Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 5:52pm
After one week of analyzing the problem with my newly purchased 1975 AC 185 for $100 basically given free from a generous couple.
The Mechanic they hired wasn't able to fix the issue of start and die problem and pointed out that it is a transmission problem.I know from experience that it is starving of fuel and the injection pump mechanically performs well, but where is the leak and what causes it?
After following all the recommendations from the forum and methodically going to the process of elimination physically. Dr. Allis (credit)has the answer that is clog return line caused by the rubber compression fitting line intake
that started to disintegrate(line from the fuel filter to the injection pump). Cost
$.079cents. Maybe some problems are unique such as the flex ring that started to fall apart. I cleaned the crystal ball with compressed air and soaked in gasoline 1/2 fitting wrench no need to grind for me to get the ball out. It save me lots of money by being patient. Will see how long it stays running.
This tractor runs like champion!Thanks for all the input.
