AC 185
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Topic: AC 185
    Posted: 22 May 2010 at 11:37am
Will a front end loader off of a AC 190 fit a AC 185 without doing any fitting and welding? I can buy a AC 190 with an almost new loader on it for what the loader is worth.The 190 has problems and I am not interested in fixing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 1:09pm
Should bolt right on - BUT- if the loader frame runs to the back of the tractor the axle housings are different ; back at the axle housings you will need a -U- bolt and a piece of angle to mount the loader at the back ; the 190 has flat axle housings ; the 180 round and higher ;  you bolt the angle on with the -U- bolt to the 180 axle housing , the angle hangs down to the loader frame ; either weld it or bolt it together . Whats wrong with the 190 ?? Would it be for sale ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 1:45pm
Yes it would be for sale, the only thing is I am 40 miles south of Waco Tx.Its an older 190..clean but has engine problems..has not had the pan off or anything else to see how bad it is.I forgot to say that the front end loader is a KD brand.Mounts on the side plates so it doesn't go back to the rear axel.
