AC 185 rear end noise |
Big Al 485
Joined: 30 Jan 2011 Location: Ravenna Ohio Points: 42 |
Topic: AC 185 rear end noisePosted: 30 Jan 2011 at 5:28pm |
I have a 1977 AC 185. I'm hearing a whining noise in 4th high gear while running down the road. The noise seems to be coming from the rear end/ axel. Does anyone know what this could be? Such as a bearing or a worn gear? It only does it in high gear at high speeds.
kip in cny
Joined: 29 Nov 2009 Location: Jordan NY Points: 538 |
Posted: 30 Jan 2011 at 5:37pm |
have you checked your tranny oil level ? If thats not it I would start looking into the bearings
160 CA 920diesel 5020 HD-3
Posted: 30 Jan 2011 at 5:45pm |
Never seen one that didn't have some kind of whine in road gear. You just buy this tractor??? or have you owned it for years and now it is worse than it used to be??? |
DougG
Posted: 30 Jan 2011 at 5:59pm |
They all have bad gear noise !!! Grinds and growls
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2337 |
Posted: 30 Jan 2011 at 6:01pm |
Not much experience with this but I got one with less than 1400 hours I just got in 2010, it whines in high too, hoping it is normal for these.
Big Al 485
Posted: 30 Jan 2011 at 6:08pm |
tranny oil is good, i think you are right about the bearing i think its an axel bearing or something.
Big Al 485
Posted: 30 Jan 2011 at 6:10pm |
i bought the tractor about a year ago, and it has done it ever since i got it. i wouldnt say it hasnt gotten any worse.
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 30 Jan 2011 at 6:28pm |
Have you also checked the gear oil level in the final drives? Fill plugs (no drain plugs) are on the inside of of each of the final drive oil pans. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
wheatbreeder
Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 581 |
Posted: 30 Jan 2011 at 6:38pm |
do a road test drive it down the road for several miles with a load behind it high gear
Morley |
Farm stuff 8050,6690,175,F2,5050,WD
Big Al 485
Posted: 30 Jan 2011 at 6:39pm |
Yes, those are full too. It's funny, it does not do it all of the time, it is louder if you are going up a hill, and going down one too. On level ground it seems to be the quitest.
Thanks to all for your help !
Posted: 30 Jan 2011 at 6:53pm |
Sounds kind of normal. |
Lester
Posted: 30 Jan 2011 at 6:55pm |
My 185 was almost new when I brought and it has always whined in 4th gear.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 30 Jan 2011 at 6:58pm |
Was running the 175 down the road yesterday and I was hearing the same kinda noises. Reminds me of the D15, I drove myself nuts checking fluids, etc, all were fine. I'm learning to keep ears open for new noises, and not worry about normal growling, whining taht seems to be built into these machines.
wheatbreeder
Posted: 30 Jan 2011 at 7:01pm |
you need to try it with a load on it
Morley
Skyhighballoon(MO)
Posted: 30 Jan 2011 at 8:00pm |
My One-Eighty sounds the same way. Mike
Hunter
Posted: 30 Jan 2011 at 8:04pm |
lol my 185 does the same thing but i have not noticed it lately i guess cause i am so used to it. but its a very dependable tractor. the best on our farm and has anybody had problems with those ear things on the power adjust rims we have replaced two on this tractor last year and are having to replace them again along with the old ones but the other side is fine. any suggestions on what could be the problem on why this is happening and they are also always coming loose after we tighten them.
bwp
Posted: 31 Jan 2011 at 12:23am |
A friend's D19 has always made a howl or rattle noise in high 4th gear as long as he can remember, and so does mine. Both are used for completely different work, one used hard and the other not so hard. Only ever noisy in high 4th.
TexasAllis
Posted: 31 Jan 2011 at 7:04am |
I have run numerous D-17's, 190's, 180/185's and 200's. They all whine , some more than others.
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 31 Jan 2011 at 7:52am |
Back many years ago when the old cars had a whiney rear end they would put in a couple bananas!!
R.W
Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Posted: 31 Jan 2011 at 8:42am |
There is a guy by us that would buy old tractors at auctions and he would put everything from sawdust to bananas!He had auctions but he would run everybody up so everybody hated him!LOL |
