AC 175 lift cylinders guru? |
Post Reply |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10564 |
Posted: 03 Mar 2020 at 5:19pm |
How much force does it take to put cylinder rod into new seals and wipers? I have the snap ring in correct location. What is best lube for assembly? I don't want to damage the seals. Thanks Tracy
MACK
Thanks(1)
Wheel bearing grease. MACK
Tracy Martin TN
Mack, Thanks! Tracy
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3245 |
Just did one as an old man - push in past wiper it will stick - I took the assembly and 'bounced' it on the table letting the weight of the movable piston push past the main seal - which should be a tapered slide - opening lip facing away from the open end.
Post Reply | |
