AC 175 engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 175 engine?
    Posted: 21 Feb 2011 at 7:10pm
What size engine is used in the AC 175, 4.248 or 4.236, or both sizes?Thanks Tracy Martin
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:15pm
I believe in Norm's book it states that the 175 was tested at Nebraska with the 236 and was years later updated to the 248 and never retested.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:30pm
 Tracy !!  Also  the early  175  had  the  hyd pump  in belt  pulley hole  later  had  front pump.    Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 8:06pm
What would a late model engine cost? Running or a good core? Thanks Tracy Martin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:13pm
The 236 was only used for one year, then they went with the 248.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 5:49am
A friend has a 175 with the AC engine and I think it is a late model because it has the front hyd pump.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 8:52pm
Anybody got a 248 block or engine for sale? Thanks Tracy Martin
Smokey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smokey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 7:16am
All the Crop-Hustlers with front hydraulic pumps and worm gear steering had the 236 when they went to front pump and cylinder steering they had 248ci we have 2 of each. Tracy try Jim Campbell in Lawrenceburg TN.
210,220,7010 AC,7020 AC,7040 AC,7045 Pedal Tractor, 8050& 8070 and Parts and Pieces of Many More!!!
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 11:43am
I have a complete motor still in tractor, ran a year and a half ago. It had the front hyd. pump, can't remember if it was a 170 or a 175 tractor, rear end was completely chewed up was the reason it was parked and sheetmetal and rear lift was sold. All is for sale.  Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 3:25pm
Randy, I would be interested in tractor or engine. Thanks Tracy Martin
This page was generated in 0.186 seconds.
