AC 175 adding joystick and power beyond
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 175 adding joystick and power beyond
    Posted: 22 Mar 2026 at 8:06pm
Adding joystick and power beyond on my 175 D. The lines on it are coupled LH  side of tractor just beyond start of frame rail. Is there a kit for this, or does most people build their own? Where are most running return to sump from? I have a schematic, but would love to see pics of a well run one.  Any help appreciated. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 5:09pm
Any help appreciated! Tracy
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 54 minutes ago at 6:44am
I'd help if I could Tracy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 19 minutes ago at 7:19am
I have no pics to help. On a 170 thru 185, I like my joystick's location between the throttle and right fender so I can shift gears with my left hand. Power beyond valve sump return is very low GPM (when done correctly) and I'd probably remove the large return elbow on the left side of the torque housing, drill and thread it to 1/4" NPT on one side and drain the power beyond valve there.
Edited by DrAllis - 12 hours 10 minutes ago at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 19 minutes ago at 4:19pm
I'm not sure if its the same, But on D series there already is an unused pipe plug, left side, above the clutch, on the side of the torque tube that dumps down into hyd sump.  Again, not sure, I may be comparing apples to oranges...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 45 minutes ago at 5:53pm
Nope. Ever since the series 4 D-17 what you're talking about ain't there.
