AC 170 leaking hydraulic fluid from pump
waldershrek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldershrek Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 leaking hydraulic fluid from pump
    Posted: 22 Apr 2012 at 10:21am
I have a AC 170 with a front end loader we use at my parents farm. The other day I noticed the hydraulic fluid was low so I topped her off. Afterwards while moving some silage with the front end loader I noticed that when trying to lift the bucket, fluid is shooting out of the pump. This only occurs however when you are trying to lift more than the hydraulics can handle apparently. For example driving into the silage pile and trying to scoop and it's packed together and you try to lift while your bucket is still at the bottom of the pile.
It also shoots fluid out of the bottom of the pump if the 3 point hitch arms all the way up and you pull the lever like you want to raise them more (although abviously you can't because they are all the way up).
It does not shoot fluid out when just raising/lowering the bucket even with weight or no weight in it. Also, there is a little nipple looking thing on the bottom of the  hydraulic cylinder for the left rear three point hitch arm that fluid is dripping out of steadily while the tractor is running. Drips even when no load is on the hitch.
So any ideas what might be the problem?
Edited by waldershrek - 22 Apr 2012 at 10:22am
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 1:12pm
Sounds like the relief valve has been tampered with and raised too high or it has become stuck not allowing it to work. This will soon destroy the pump if it hasn't already.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldershrek Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 1:38pm
Is the relief valve in the pump or is it somewhere else? I have the repair manual for the tractor and it shows the exploded views of the pump and the relief valve but it does not show or tell how to get them out of/off the tractor. My tractor serial must be under 7500 because the pump is on the right side of the tractor just forward of the operator platform. Fortunately I think I caught it early enough to prevent any serious damage as the tractor is not used daily and just started doing this when I noticed it.
Edited by waldershrek - 22 Apr 2012 at 1:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 3:19pm
Pump needs to be removed, disassembled and resealed at a minimum. There also could be a crack in a section plate. Check pressures with a 3000 psi gauge plugged into a remote outlet and stall the pump...2400 psi max at full throttle.  I doubt if that's the problem...relief valves don't change by themselves. Leaking hydraulic lift 3pt cylinder needs to be resealed.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 10:05pm
Relief valve is in valve stack behind the levers and to your right setting on the seat.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldershrek Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2012 at 8:29am
Thanks for the replies so far guys.
The tractor doesn't have to be split to remove the pump does it? It's right on the side and looks like there is easy access to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldershrek Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 9:41am
Does anybody know?
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 11:13am
The tractor does not have to be split to pull the pump.  The early 170s were like the d17IVs and if you take out four bolts  you can pull the pump off.  When you do watch out for the shims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waldershrek Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 11:52am
Ok that's what it looked like thanks!
Edited by waldershrek - 24 Apr 2012 at 11:56am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2012 at 9:48pm
Take the 2 bolts out that hold the pump to mounting plate. There are no shims at this place.  MACK
