AC 170 hydraulic hard line replacement
AddictedtoAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AddictedtoAllis Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 hydraulic hard line replacement
    Posted: 4 hours 34 minutes ago at 8:58pm
Hello!
I have a hole in the hydraulic hard line for the lift arms.
Anyone know where I could get  a replacement one?
It's the later 170 model with the hydraulic pump in the front.. the short section in the front to the pump is fine, but the back half, just behind the fittings that connect the front line to the rear half is where the hole is.
Thanks guys!
Edited by AddictedtoAllis - 4 hours 33 minutes ago at 8:59pm
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 8 minutes ago at 9:24pm
What kind / size hole; pin, worn thru, cracked?
 A lot of lines w small holes and even cracked almost into 2 pieces have been repaired by brazing the area. It's an option if you can't find a replacement line.
OR a hydraulic hose can be fabricated to replace it. IT won't look OEM to the purists, but it does cure the leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AddictedtoAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 45 minutes ago at 9:47pm
Thanks for the quick reply! It's a small worn through spot. I didn't even think of brazing! I'll probably give that a go first!
Thanks!
