AC 170 gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 170 gas
    Posted: 6 hours 32 minutes ago at 7:02pm
I noticed my gages did not read power today. Put a new battery in it, thought old one was bad, didn't seem to hold a charge. I wonder if my tractor is charging now. Gage doesn't show it.Has factory alternator with the regulator under battery. What is easy way to check this out? What is most likely fix? Thanks, Tracy
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 12 minutes ago at 7:22pm
   My quick and dirty first step is to get a reading on the voltage with engine stopped and with engine running.No change then pull alternator and take it to a parts store to check function.
   It has been the year of the crapped out charging systems for me.One of the D17's,the CA 6 volt genny and Big Al the gas passer(7020 gas) all needed work.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 38 minutes ago at 7:56pm
First check to see if the regulator under the battery on the torque tube has a good ground,  the resistance from the bottom mounting plate of the regulator to the tube must be much less than one ohm in order to regulate and charge properly!
Some regulators had a short stranded wire to make this connection.
Clean all!
