AC 170 Gas crankshaft pulley install |
AddictedtoAllis
Topic: AC 170 Gas crankshaft pulley installPosted: 10 Oct 2024 at 11:44pm |
Anyone have any advice or know the proper way to install a crankshaft pulley on an AC 170 gas crankshaft? Thanks |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Posted: 11 Oct 2024 at 5:42am |
Nothing special to it. Slide it on and run the setscrew into the dimple of the crank. If the engine is still in the tractor, I'd about bet the steering pedestal has to come off first. AaronSEIA
Posted: 11 Oct 2024 at 5:56am |
Be sure to get the set screw TIGHT so the pulley doesn't shake loose after a time. The pulley should fit the snout of the crankshaft slip fit tight. It cannot be loose on the crank. If so, I have a repair for that.
Edited by DrAllis - 11 Oct 2024 at 6:31am |
AddictedtoAllis
Posted: 11 Oct 2024 at 10:50pm |
Thanks guys! Appreciate the quick reply!
