AC 160 Rotary cutter |
| Author | ||
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: AC 160 Rotary cutterPosted: 08 Sep 2018 at 7:10pm |
I know it probably has been asked before.Can you still buy the blades and bolts for the 160 mower? Is aftermarket available? Thanks Tracy
| Sponsored Links | ||
garden_guy
Joined: 05 Jul 2013 Location: Illinois Points: 1167 |
Posted: 08 Sep 2018 at 7:20pm |
I'm in the same hunt myself. My blades are a bit worn, and I'm pretty sure I'm going to have to hot wrench the nuts off (and broke off the cotter pins, too). When I asked recently, I was told maybe Agco has the castellated nuts and bushings, but they're $$$. But the blades I don't recall an answer on. ![]() ![]() |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 08 Sep 2018 at 8:11pm |
Don't know if I posted on this before, but what I did, years ago, was to measure the drop, and the length, and match up as close as possible... IIRR, the drop is the limiting factor. Again, IIRR, original drop was like 4-1/2", and the closest I could find was 3-1/2"...
You might try agrisupply, they do have a big selection, and I didn't know about them, back then...
ac160
Posted: 09 Sep 2018 at 4:12pm |
Quite a few years ago I bit the bullet and bought new from AGCO.
Tracy Martin TN
Posted: 10 Sep 2018 at 9:17am |
Where is the serial number on these mowers? Does anyone have a parts manual of one? Thanks Tracy
Travis(NE)
Joined: 24 Sep 2009 Location: Seward NE Points: 300 |
Thanks(1)
Posted: 10 Sep 2018 at 4:29pm |
Don't tell anyone, but...
When I was working on mine I took all the parts to the local John Deere dealer and they were able to match up everything I needed. There is a bushing in the blade they didn't have, but it matched up very close to a bearing lock collar and I've been using it like that for years now.
DiyDave
Posted: 10 Sep 2018 at 5:55pm |
The bushing is pretty much the same, in almost all bush hogs 3/4" ID X 1-1/2" OD. thickness is a little thinner than the blade...
Tracy Martin TN
Posted: 10 Sep 2018 at 8:29pm |
Travis(NE)
Posted: 11 Sep 2018 at 9:38am |
I honestly couldn’t answer that as it’s been probably ten years ago or more since I did that. The JD parts had to of been pretty reasonable if I bought them tho, if that helps. |
ac160
Posted: 12 Sep 2018 at 6:56am |
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 12 Sep 2018 at 1:40pm |
Tracy, send me the dimensions with hole size and blade offset and I'll look at our co-op. Seen a bunch there yesterday.
Tracy Martin TN
Posted: 12 Sep 2018 at 2:58pm |
Scott I haven't taken them off yet. Putting on new lift lower lift links and cranks on the 3 point hitch. Going to try to this weekend. Thanks Tracy |
allisrutledge
Posted: 12 Sep 2018 at 9:24pm |
No problem, just let me know when you get one off. I seem to visit the co-op quite often. Scott
Phil48ACWC
Posted: 13 Sep 2018 at 6:54am |
https://www.agrisupply.com/blades-rotary-cutter/c/1900007/pgnum/1/pgsize/all/
Click on above and try matching to yours.
Tracy Martin TN
Posted: 13 Sep 2018 at 1:21pm |
Thanks, I will check them out. Tracy
Tracy Martin TN
Posted: 13 Sep 2018 at 3:49pm |
Got my parts manual today. I can see what is available now.Kinda neat to see what options they had also. Thanks Tracy
Edited by Tracy Martin TN - 13 Sep 2018 at 3:50pm |
DiyDave
Posted: 14 Sep 2018 at 5:40pm |
bump to top, so i can see replies, before it gets to the unaccessible 2nd page...
Travis(NE)
Posted: 14 Sep 2018 at 10:31pm |
What did you do to the second page!
DiyDave
Posted: 15 Sep 2018 at 7:12pm |
