AC 160 fuel |
John WV
Joined: 30 Oct 2010 Location: bunker hill wv Points: 280 |
Topic: AC 160 fuelPosted: 21 Feb 2026 at 11:04am |
does any one know I can fix a cav fuel injection pump throttle shaft seal on my i can see fuel coming out and drip off the botton of the pump . on hydraulic on the 160 i put on new pump and new fluid allis chalmers 821power fluid but lifting slow and half throttle before lifting any weight
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 158 |
Posted: 21 Feb 2026 at 12:14pm |
On the injection pump it is a fairly easy fix, it can be done on the tractor. There are several different kits available, we did the throttle shaft on my brother's 1068 New Holland two years ago. The kit I found had new shafts, seals and the aluminum cover, we only needed the shaft and seals. Several decent youtubes covering the repair, the only difficult part I remember is making sure to pay attention to where the spring is attached when you take it apart.
https://photos.app.goo.gl/QmNNbijEq3oPYmT77 Edited to add pictures of the part kit I used. Ted Edited by TedN - 21 Feb 2026 at 6:08pm |
