AC 160 fuel
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 fuel
    Posted: 21 Feb 2026 at 11:04am
does any one know I can fix a cav  fuel injection pump throttle shaft seal on my i can see fuel coming out and drip off the botton of the pump . on hydraulic on the 160 i put on new pump and new fluid allis chalmers 821power fluid but  lifting slow and half throttle before lifting any weight
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2026 at 12:14pm
On the injection pump it is a fairly easy fix, it can be done on the tractor. There are several different kits available, we did the throttle shaft on my brother's 1068 New Holland two years ago. The kit I found had new shafts, seals and the aluminum cover, we only needed the shaft and seals. Several decent youtubes covering the repair, the only difficult part I remember is making sure to pay attention to where the spring is attached when you take it apart.
https://photos.app.goo.gl/QmNNbijEq3oPYmT77
Edited to add pictures of the part kit I used.
Ted
Edited by TedN - 21 Feb 2026 at 6:08pm
