AC 100 series dash cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 10:45am
A real red neck farmer fix would be to build a battery holder mounted to side of frame rail and run new cables.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 1:53pm
Key word……..Redneck.😫
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:48pm
That was a great idea from A-C! If you ever serviced a 170/175 tractor you will love that design. They are on every 170/175 tractor, not as an option. There are 2 cotter pins that are usually in the end of the 2 pivot pins on that flip up shroud. They hold the shroud in place on the sides of the instrument panel. Most tractors that I've worked on have the 2 cotter pins removed to facilitate removal of the whole shroud in less than 2 seconds. Now if only the same engineer would have designed the hood!
www.awtractor.com
A&W TRACTOR 920-598-1287
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 2:23am
Remove two pins and flip the hood up?
That would have been sweet.
This page was generated in 0.058 seconds.
