AC 100 series dash cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 100 series dash cover?
    Posted: 14 Apr 2025 at 10:47pm
Has anyone ever had one of the flip top dash covers that had a working closing knob? I have yet to see one. Every one of mine that is a sore spot. None work like they should. Another peeve is the battery location on the 170-175 tractors. Not as much as location, as what is involved in replacing one. Especially with a loader. Thanks, Tracy
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 13 minutes ago at 5:18am
I have never seen a flip top dash cover. I didn't know they existed. Were they original equipment or aftermarket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 12 minutes ago at 6:19am
170 and 175 only. As an old dealer, I've been around many and they always seemed to work for me.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 35 minutes ago at 8:56am
Tracy, Yeah battery location is not the best. It is closer to engine starter which helps for shorter cables. I've used shorter height style battery in the 170-175s, which can allow a little more space up top for attaching/detaching battery cable terminals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 8 minutes ago at 9:23am
Be nice to see a picture of what you're talking about.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 6 minutes ago at 12:25pm
Mine doesn’t work right either
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 1 minutes ago at 2:30pm
My grandfather bought this 175 in 1978 when it was a year old.  I grew up on the tractor, and that latch never closed properly.  Over the years, the hood and cowl had been removed numerous times - no difference.
When I restored the tractor in 2015, surprise surprise, the latch actually closes now!  I can't explain it and I don't know what I did.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 33 minutes ago at 3:58pm
The triangular (viewed from either side) sheet metal cover that wraps over top the dash gauges & secures to the hood out front of the dash with a twist toggle. All the 100 series tractors have them(170,175,180,185,190,200,210?,220?,160s is integrated into hood??). Believe the 190s has 4 stove bolts securing theirs? I don’t know about rest.
Anyway this cover (only on the 170s?) has two studs that are located to the side of the gauge clusters & about half way down front the top of it. There’s enough spring tension inherent of the 90 degree bents of the cover which keeps the studs inserted into receptacles (welded washers? on each side of gauge cluster. So the twist toggle is the only securing piece for cover. If it doesn’t catch & hold then dash cover will be loose??
Edited by AC7060IL - 9 hours 30 minutes ago at 4:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 50 minutes ago at 4:41pm
7060: only the 170 and 175 use this cowl. All the other models are bolted in place - my 185 and 190 are secured with a number of bolts.
If it isn't latched, it will not go anywhere but will vibrate against the hood, with a slight rattle coming from the wing nut latch. To answer your question, yes, the "twist toggle" is the only thing that secures the cowl to the hood. It sits on pins on either side, but the "springiness" of the cowl keeps things snug along the sides.
Edited by DSeries4 - 8 hours 45 minutes ago at 4:46pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 28 minutes ago at 8:03pm
The one on my One Seventy still works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 28 minutes ago at 9:03pm
That latch is a POS from my perspective. It should of had a good spring under the locking pin to hold it tight. Slightest amount of wear allows it to loosen and vibrate like hell. JMHO, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 44 minutes ago at 10:47pm
Still don't see/understand what/where this cover is/goes....
