A-6 air conditioner compressor
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: A-6 air conditioner compressor
    Posted: 11 Oct 2025 at 8:54am
I spend whatever it takes to have working AC. 2 Gleaners 3 8000's. That's just me.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 4:29pm
Yra, Darrel,, and my thoughts are,, if it's got it,, it needs to work,, an with my hay fever/allergies,,I kinda need it to work, especially mowing weeds, or cutting hay
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2025 at 5:29am
Good morning, Michael. Any time you can fix something for 130 bucks in this day and age, call it a win! Down there where it gets hot, you need to stay cool! Have a good one! Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2025 at 8:58pm
Well, I ordered a clutch hub off the interweb, looks like it's the right one,, so,, the Ole A-6 gonna live a little bit longer. For nor more than I use tractors any more,, be a long while before I change to a sanden, although, that is preferred, just to many dollars for the few hours a year I put on the tractor nowdays
I only gots about $130 in the A-6 as of now,(clutch coil,bearing,hub) not counting occanasional can of freon or 3
Edited by Michael V (NM) - 08 Oct 2025 at 9:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2025 at 4:03pm
I recently put a clutch coil and bearing on the compressor on my 7060, well,, now the clutch hub decides to self distruct,,
Now being somewhat resourceful,, I thought I'd take the clutch hub off the compressor I replaced on my cadillac,, same compressor,,right, oh, but NO!!,, I don't think there are any 2 of A-6 clutches that are the same,grrrr
If that isn't a problem,, the belt groove will be in a different place on the drive hub....luckily, I not having to change that...
Edited by Michael V (NM) - 02 Oct 2025 at 4:06pm
This page was generated in 0.135 seconds.
