a tip if things go bad on your 5020 front end |
dt1050
Joined: 05 Jul 2011 Location: central pa Points: 1078 |
Topic: a tip if things go bad on your 5020 front endPosted: 03 Mar 2017 at 6:34am |
My son was using my 5020 4x4 to pull logs down for a friend to cut up for firewood. I heard the tractor shut off and seen the boy walking down the hill....well that can't be good. Right front wheel locked up. Not wanting to make things worse I put a couple of logs under the loader buck and lifted the front wheels off the ground and steered with the brakes. It worked got off the hill and into the garage without messing up any of the gears, only had to replace the bearing that went bad.
So if you find yourself in that situation and have a loader, shove sum logs, lumber, metal pipe, etc. under the bucket and lift your front end off the ground. If you start chewing up the gears in the front axle it's gonna get expensive fast!! |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 03 Mar 2017 at 7:54am |
are those full time 4x4?
dt1050
Posted: 03 Mar 2017 at 9:14am |
no there's a lever under the seat to put it into 4 wheel. but the final drive gears in the front axle/hub still turn in 2 wheel.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 03 Mar 2017 at 12:29pm |
on a similar note... if you have a D-14 be SURE BOTH bolts holding the steel plate that holds the 'wishbone' on are TIGHT !.....
Yup, one 'fell' out on me...furthest corner of the property(Murphy's Law) and the WHOLE front axle kind slipped out....... |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3556 |
Posted: 03 Mar 2017 at 1:23pm |
not only expensive,,, elusive...
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 03 Mar 2017 at 3:45pm |
Wow - having the front end "kind of slip out" sounds thoroughly annoying!
Clever idea to create a skid for the front end!!
WC, CA, D14, WD45
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54738 |
Posted: 03 Mar 2017 at 6:27pm |
There's another way. Most wf's have a limiter stop, to keep the FE from rising up to hit the sheet metal, on the tractor. Find that spot, jack the tractor up, with the lame foot up in the air, and stick a wedge between the axle, and the stop, tape, wire, or chain the wedge in place, and you can limp home... There's a video of an old man and his wife, on the opposite fender, with only 1 front wheel, riding in a parade, I think the tractor is a romanian ford...
DougG
Posted: 03 Mar 2017 at 7:30pm |
True Allis models had the BOLT break out too , my Uncle was discing with a 170 once and BAM, the front end was right in front of the back wheels
dt1050
Posted: 04 Mar 2017 at 2:24pm |
Not sure were they are, but the sure are elusive!! never had any of my front ends come apart like listed above, certainly doesn't sound fun!! |
