A Super Duty Starting ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: A Super Duty Starting ??
    Posted: 02 Oct 2021 at 8:36pm
My buggy is becoming more and more tempermental as far as a VERY loose gear shift lever in the "column"ConfusedOuch . More and more often I have to "pull-up" on the gear lever to engage the starterCryCry What type of "fix" am I looking at $$ wise and is something that can be "remedied" in my driveway with "basic" tools ?? Thanks
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2021 at 9:12pm
It all depends on where the linkage is worn out. If it’s mostly in the linkage that is buried in the steering column, it may be best to have a service center to the repair. If it’s more on the linkage down near the tranny, there it’s possible to do your self. It all depends on the make, model, age, etc., of the vehicle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2021 at 11:47pm
The shift linkage in the column is incredibly simple. There’s a clamp that gets loose and a bushing that wears out. The hard part of the repair is pulling the steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 12:51am
yep....what Brian said
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 6:42am
I got a beater 2001 that dealer redid the shift column to fix the tugging to get it to start.  It made it better but not perfect
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 10:31am
I had mine done,cost about 200 bucks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 5:52pm
At a dealer or independent  shop ?? Thanks for the reply Clap
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 7:52pm
Independent shop
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 7:57pm
Thanks Tom Clap
