Unofficial Allis Homepage
A Story About "Allie", The 1953 WD
 Post Reply Post Reply Page  <123
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2021 at 9:21pm
Looking good!!!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2021 at 6:35am
Doing great. Keep it up
Jtaylor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 6:44am
Made some more progress on the tractor last night sandblasting. almost finished the back half anyways.
and, after sandblasting the crud off the shift tower, take a look at the twisted number "1". You could say its a "one-off" LOL
Now, I just need to get the correct Primer, What does everyone suggest? looking at painting in the springtime with PPG 60080 single stage (MTX) or the vansickle paint if i can get down to the USA sometime soon..
Edited by Jtaylor - 09 Nov 2021 at 12:15pm
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 12:04pm
Looking good!!!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 2:06pm
That number “1” is pretty unique. Wonder how many went down the line like that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2021 at 3:40pm
Yes I like the number "1" also! I have never seen one like that. Very rare and expensive unit you have there! The cleaning is coming along nicely! Keep at it! There are a lot of nooks and crannies to get the protective coatings off of. I have found most of them and daubed some paint on places no one will ever see.
Its going to look real good in PO#1!
Thanks for the update!
D17 1958 (NFE), WD45 1954 (NFE), WD 1952 (NFE), WD 1950 (WFE), Allis F-40 forklift, Ford Jubilee, Many IH Cub Cadets, 32 Ford Dump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 7:49am
Well, Let the money spending commence!
here was my cheap pickup from Princess Auto (canadian harbor freight). Cotter pin kit, "R" clip kit and the pin for $30. Cant beat that!
The pin was suggested by a local farmer for the replacement hand clutch. He suggested to cut down one of these pins and drill a hole for the cotter pin as a replacement for the transmission mounted pivot. at $10.99, it was a much cheaper (and shorter) option than 7/8 cold rolled steel ($55 here for 4 ft)
We also picked up the primer required for the cast iron. the local paint expert suggested epoxy primer since it will be sitting until springtime for paint. this was quite expensive but well worth it for the correct paint finish. $232.50 for 2 usable gallons. mixing at 1:1
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 8:49am
Nice.
That cotter-pin kit should be required before being allowed to farm. Don't know how many nasty scratches I've had from some rusty nail bent to work as a c-pin!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2021 at 8:14am
Well, I am finished for the time being on the sandblasting side of things. here is how it turned out.
I have started on the repairs to the transmission shift forks (that are bent) so i have removed the cover and set it on the bench for the time being.
I also wanted to replace the hand clutch shaft while the cover was off. I got my punch set and a couple of rather large hammers ready. I heated it up with map gas as hot as i was comfortable with and started to pound the shaft out from the inside. no luck! didnt even move a tiny bit.. it looks like i will have to get things a lot warmer for it to expand enough. any tips from the ones who have replaced it before? it is beyond repair in my books and would rather it be replaced with new than repaired.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Nov 2021 at 8:33pm
Justin,
 Sandblasting for clean up looks good. I did one pin replacement and did not do a good job. The hole in the case was wollowed out. I attempted to drill it and put in another pin. I did not have the tools to do it right and it still iss loose and leaks. I assume this pin really needs to be pressed out and in for a correct job. I have welded up several of them to my satisfaction and hand worked them back close to round. Mush better than they were in the worn state. And then also re bushed the handle. Took out 90% of the slop.
Keep at it!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 7:58am
Hi Justin- GREAT WORK!!!
On that pin... either lay filler across it with a MIG, then follow up with a 4" angle grinder and a flap-disk to hand-form it back to round, or grind it DOWN to a slightly smaller OD, and make  a sleeve that will slip over.  Drill a hole in the sleeve about where the deepest divot is, then fill INTO the hole, which will not only fill the void, it will also secure the sleeve...
Then dress the hole you welded shut to round and smooth.
Do re-bush the inside of the lever.
Take the guys' advise on the hand clutch, and while you're in there, make certain that none of the pins can migrate loose and fall into the PTO gear housing.  Don't ask me how I know... LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2021 at 2:01pm
We have success!
The pin was removed. a couple of good hits with the hammer and it started to move.
Here is a side by side comparison of the original pin and the new pin that i made up.
I ultimately had to finish splitting the tractor in half to get the new pin in place correctly. that required removal of the pulley and removing the front end to set aside. here is some not very pretty photos of that process.
I will be disassembling the front end at some point, although this was just fine for the time being.
I started on removal of the bushings for the clutch handle. they came out as expected.
Might just have to repair these pins prior to reinstallation. they are quite worn. hand clutch linkage pins.
I have also purchased the paint required. That was quite expensive but it is the correct color and finish type. I look forward to laying that down ASAP.
Thanks everyone for the input! very helpful!
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 7:05am
We enjoy watching your progress. Thanks for the updates and pictures. Good work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2021 at 8:47am
And.... We have paint! I spent the extra money on PPG MTX paint. Code was 60080 Allis Persian Orange. Looks very close actually. I am pleased with the color.
And, As recommended by the body shop, this will be used as the final skim coat on the frame rails and tin. just to make things smooth and nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2021 at 5:44pm
Justin,
 Looks like your work is progressing nicely! Paint looks proper too!
Stay at it. Do you have the weather to get it in primer? I spent a lot of time on some of mine and could have spent double that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2021 at 9:27am
Justin,
Thanks! I have some heat where needed for the primer to work correctly. should be good here in the next few days to get it primed and prepped for paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2021 at 9:31am
A little more progress with the pre-primer prep.
Got the hand clutch pivot pin installed into the frame of the tractor. freezing this pin and heating the casting made this a 10 minute project. its even the correct length!
I also plugged away with cleaning some remaining gunk from the small hard to reach areas. brake cleaned all the areas i needed to and got the unit much closer to primer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 11:54am
Most brake cleaners will leave a residue that will make the primer not stick. I tried it once on a different tractor I was painting and it peeled later on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jtaylor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 1:02pm
The plan was to use the brake cleaner to remove the gunk, then as requested by the proform folks was to lacquer thinner the whole chassis prior to priming. they say that is the best combo for my application. they also recommend to off gas the cast iron for about 1 day after the lacquer thinner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 37 minutes ago at 5:48pm
J,
Pivot pin looks great! Your almost there. Prep is the biggest part of the project.  Stay at it! Fresh paint is a great accomplishment!
