A Pepsi Challenge |
Post Reply |
Dave H
Orange Level Joined: 11 Sep 2009 Location: Central IL Points: 3491 |
Posted: 31 Oct 2018 at 6:04pm |
I have four inch guttering. I need to punch a hole in it for another down spout. I have seen the tool to do this but i hate to do the 50 buck service call to have one punched in. How would you all go about this from a farmerized perspective?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80218 |
air or electric grinder with a 4 inch cut off wheel.
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10606 |
Hole saw and compound aviation snips. Tracy
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 974 |
Hammer, chisel, duct tape. And probably a band-aid.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33780 |
Shot gun, BLAM, hole made, now to finish with circular tin snips... if there's anything left
Grayray
Orange Level Access Joined: 12 Sep 2009 Location: Ambridge PA Points: 3808 |
Draw out the area you want to cut out. Use an old beat-up wood chisel to punch a hole in the center then use aviation snips to cut it out. This is all I ever used when doing gutters and downspouts, I've done hundreds of them this way.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22269 |
Ask Shameless to redirect his 'machine'...there now you don't have to make another hole cause it's all covered with that white stuff he loves to share....... neighbour just upgraded his troughs from 5 " to 6", didn't know 4" was still around..you don't get a lot of rain ?? up here 'tin whackers' must have got their nickname by the way they install .Whack a screwdriver through the gutter, hack with snips,use 1/2 tube of sillycon to seal. The sad thing is I can use a proper die set in LESS time and do the job RIGHT. Jay
Dave H
Well glad i asked, I m going to start with Tracy's suggestion with the hole saw. Why didn't I think of that? Well maybe they re 5 inch, I did not measure before I opened my pie hole. Thanks folks.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11544 |
PERFECT!!!!
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
It appears on mine they just cut an X and folded the tabs down into the downspout.
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18786 |
Post Reply | |
