a long shot.........part needed.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: a long shot.........part needed.
    Posted: 11 May 2016 at 8:48pm
Does anyone have a adjusting crank for a 209 Simplicity cultivator? its #2 in the pic. thanks Tom
Edited by ctbowles58 - 11 May 2016 at 8:53pm
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 9:43pm
should be able to make one pretty easy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 9:46pm
yes it shouldn't be too hard, but I have to find a 7/16 left hand die.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 12:32am
not if you change the threaded part it screws thru. a couple nuts, one each end of a short pipe! it just hasta screw up and down!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 7:12am
A good machine shop should be able to turn left hand threads.  A quick eBay search came up with a die for $9.  I never realized it was left hand threaded.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 8:02am
AaronSEIA
half of it is right-hand and the other half is left-hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 8:25am
That complicates things a bit.  I have one in my shop, but haven't played with it enough to know.  It'd take a machinist with a lathe to turn that setup.  If you are on Facebook, there are a couple of Simp/AC garden tractor pages.  www.simpletractors.com has a classified section.  It's a club, so there are dues, but I think you can post a non picture ad and I know you can read the ads.
AaronSEIA
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2016 at 8:52pm
just get a adjustable top link for a 3 point - has both left and right threads - and modify to fit your use
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 6:32am
Problem with that Coke, is the adjuster in question is 7/16" rod  and maybe a foot long.  For a cultivator that goes behind a garden tractor.  I do wonder though if a small turnbuckle couldn't be made to fit somehow.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 8:02am
I have 2 or 3 of those cultivator frames out back. I'll look today to see if there is a hand crank on any of them. Knowing where they have been for the last 30 years, it might be better to make up a new one Ermm
Edited by CTuckerNWIL - 15 May 2016 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 10:19am
after working on it I think I can save the old crank,thanks Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 12:04pm
If it's still there a good shot of Sea Foam penetrating oil and a wire wheel on a drill can work wonders.
AaronSEIA
Dave in PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in PA Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2016 at 12:12pm
Sea foam, what about PB Blaster! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2016 at 8:13pm
That is good stuff too. Forget what can I'm shooting with now, but it is some darn good stuff.
AaronSEIA
