a little help
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: a little help
    Posted: 30 Mar 2014 at 1:18pm
Got a 7040 pump is maxed out it has very very little smoke and is lacking on power has a dm4 on it I thought the injunction pump was turned down so I got in to it and got a 1/4 turn on one of the screws and the other one wouldn't move.is the dm4 pumps maxed out from factory I now its not making 140 HP can any one help me
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2014 at 8:29pm
Their is a lot more to turning a DM4 pump up, than screwing the leaf screws down, the roller shoes, need to shorter for 1 thing. Your pump probably has a delivery valve stop leaking. That will leak the fuel back in the pump that should be going to the injectors. Take it off & let a pump shop help you out.  GOOD LUCK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2014 at 5:54am
Ok thanks
