a heads up when buying carb kit
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: a heads up when buying carb kit
    Posted: 17 Jan 2026 at 11:06am
I bought a carburetor kit with a new needle and seat for a Marvel-Schebler TSX-470. The seat would only thread on about a half a turn and then tighten up so much to where it was becoming destroyed, the old one threaded on easily. The thread dimensions were correct but the thread length was .008" too long. If you run into this take a fine file and gently file down the length of the threads. It threaded on easily after that. Don't force it or you'll run into big trouble. The Quality of these kit's are getting worse and worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 2:47pm
A brand name of this kit, or where/who you bought it from would be helpful. It may have been one and only one seat that was bad. But, there may be dozens of them out there bad.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2026 at 3:24pm
That's what we get with so many things that are made in countries that use metric measuring, something always gets messed up in the conversion to inches. Thanks to overpriced union labor most everything is made in some third-world country now where quality control isn't important
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 59 minutes ago at 1:29am
The thing about that union labor....most likely had some over-paid mgmt stooge that couldn't even sharpen a pencil standing there with a stop watch complaining about worker taking time to check the threads and other dimensions, etc.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 3 minutes ago at 11:25am
Anymore carb parts are like ignition parts-made in China and hot or miss on quality. I rebuilt the engine in a MF 2135 industrial tractor for a guy about 2 years ago. Took 2 needle/seats and 3 floats before I got a combo that worked.
Same guy-skip over to an Oliver HD46. 3 cylinder Hercules. Went through numerous sets of points.
Mags, carbs, distributors, points and condensers are all antique technology that no one uses anymore and none of that stuff is made in the U.S.
1968 D15D,1962 D19D
