a heads up when buying carb kit
J&J View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J&J Quote  Post ReplyReply Direct Link To This Post Topic: a heads up when buying carb kit
    Posted: 3 hours 42 minutes ago at 11:06am
I bought a carburetor kit with a new needle and seat for a Marvel-Schebler TSX-470. The seat would only thread on about a half a turn and then tighten up so much to where it was becoming destroyed, the old one threaded on easily. The thread dimensions were correct but the thread length was .008" too long. If you run into this take a fine file and gently file down the length of the threads. It threaded on easily after that. Don't force it or you'll run into big trouble. The Quality of these kit's are getting worse and worse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 44 seconds ago at 2:47pm
A brand name of this kit, or where/who you bought it from would be helpful. It may have been one and only one seat that was bad. But, there may be dozens of them out there bad.....
