A CAMPER SPECIAL ?
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: A CAMPER SPECIAL ?
    Posted: 29 Jul 2021 at 8:10pm
Back in the early/mid '70's , there were CAMPER SPECIALS available in the Ford models of pick ups, what "made" them "special" and did other manufactures offer this "package"  ??
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 8:36pm
GM did. But I don’t know what made them special.
Edited by Ed (Ont) - 29 Jul 2021 at 8:37pm
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 8:44pm
Fords had a longer wheelbase, factory pigtails for trailer hook ups, many were on a F-350 frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 9:00pm
Dodge had the first mas produced class A motorhome, ford had the 3/4 ton camper special pickup, they also put out a pickup mounted camper that was all fiberglass, after a few years on them they would start to squeak, the fiberglass and foam rubbing together. GMC had a class a motorhome, was all fiberglass, had an Oldsmobile engine and front wheel drive. still see quite a few of them still on the road yet. toyota had there class c camper, still see a few of them out there yet. most of them caught fire and burned to the ground. there were also alot of class a motorhomes that were made and put on different chassis, gave people a choice of what drivetrains and/or frames they wanted. alot of those are still being built today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 9:03pm
Seems like my grandpas Ford was a F150 "camper special" ?? It was brown and had an "extended cab" if memory serves, I was 7 LOL
He put a "truck camper" in the bed Wink
Edited by FREEDGUY - 29 Jul 2021 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 9:04pm
did it have the "camper special" chrome words rivited on it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 9:08pm
seems like it was a decal, I do recall the chrome version of designation though on other models Wink
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:16am
I had a couple chevy camper specials. they had one extra leaf and a rear bumper that you could extend out past the lowered tail gate. the camper special badge was the only other differance. Nieghbor had a ford camper special it had a side compartment below the bed and one extra leaf and a badge on the side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 8:51am
All FORD Camper Specials had a tool box built into the bed fender, behind the passenger door... at the bottom..... I dont think the F150 was ever a "CAMPER" special.. I was thinking in the mid 1970s they made a TRAILER special F150.. and it had the tool box.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 12:01pm
Dad had 68( gee how time fly's and the memory) Ford 100 had the tool box on the bottom front of bed. Not a Camper Special, several friends of his did.
They had to have more springs/suspension to keep from swaying with the big slide in campers of the day.
Edited by Ray54 - 30 Jul 2021 at 2:34pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 3:49pm
I have a 1974 Chevrolet C30 one-ton made specifically for carrying a slide-in camper.
There is no emblem on it saying Camper Special, but it's missing a fair amount of it's emblems.
The differences:
It has a Dana 70HD rear axle, full float, 4.10 ratio, limited slip.
Single rear wheel.
Standard spring stacks
11 foot extended step-side bed.
350ci 4bbl turning a Turbo-Hydramatic 400.
The serial number range for this model only spans about 4500 units made in 1974... they were all special order.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 4:04pm
There were few made and ALL had a Ford Camper Special HARD Emblem attached and only in F250 Chassis.  WB was 6" longer, bed was also at 8'6" Inside dimension, there will be a Door on the Passenger side of the Bed side panel where the spare was hung on the frame, Made in early 70s and discontinued, I owned one in '79.
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 5:14pm
The differences:
Single rear wheel.
Seems you could special order about anything from GM back in those days.
Stepdad had a 77 GMC 1 ton dually that was a camper special had a tipi emblem behind the door on the cab and he ordered it with a 454 with "rv" cam and 456 rear end.  You could pass everything with a 24ft gooseneck with 15,000# of cattle in it except a gas station.  His cousin ordered a 77 1 ton 4x4 single wheel GMC with a 350 truck motor (cast rods and pistons) with a 4 speed, it was no racer but pulled very well.
JTOOL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote JTOOL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 7:37pm
Only saw one when I worked at Western Auto back in the early 90's. If I remember correctly, the wheels were 8 lug and the outside mirrors were larger and further out from the cab/door.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 7:53pm
FORD offered it in the F250 and F350...
The F350 was called the SUPER Camper Special... Had the rear axle moved back 8 inches with same 8 ft bed... Carry a lot more load by moving wheels back further under the "in bed" camper..
Edited by steve(ill) - 30 Jul 2021 at 8:05pm
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 3:00pm
  And now all pickups are 4 door and 6 foot beds
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 7:00pm
Sadly., the "beds" are closer to 5' beds ConfusedCry
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 7:34pm
I had a super camper special like the one above. F350 that had a dually rearmed under it . It had no bed when I bought it. Or really drove good.
I hauled all over the country with that truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2021 at 8:28pm
Dodge offered a camper special for many years. Last one sold new that I am aware belonged to a good friend of mine, just sold it last year. He bought it slightly used. 1998 4 door long bed. Tow package, 4.10 rear end. Extra leaf spring in the rear, heavy duty brakes, heavy duty alternator and dual batteries. Extra capacity transmission cooler. V10 gas engine. Had camper special badge on it. I’m sure I’m missing some other options but that’s what I remember at the moment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2021 at 7:36am
Had a '77 Chevy K20 Scottsdale with Camper Special Package, mirrors were situated on large extended supports where could be rotated inward and used as conventional Pickup or Rotated outboard to see around a slide in camper.  I bought the same mirrors and adapted to my rebuilt '69 Dodge W300 that became a '73 by recab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 1:03pm
Had a 71 Chevy 3/4 ton CS. 402BB and T-400,Dana 60 with A/C and am-fm. Well used when I got it. Would have been a sweetheart new. Had the big mirrors too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2021 at 7:40pm
Did a "camper special" have a factory installed spare tire carrier in front of the grill or was this something my grandpa installed on his own ?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2021 at 9:28pm
I have a 71 C20 Chevy that had an 8 1/2 ft bed. I had a 72 C3500 GMC which also had an 8 1/2 ft bed. Both had Eaton rear axles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 5:38am
Camper Special Spare was behind the Right Bedside compartment door.  Nose mounts were a aftermarket.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2021 at 1:42pm
Two friends & I were headed to a tractor show & saw a 1970's era Dodge Class C motorhome at a rest area.  Looked to be in pretty good shape.  Impressive that it's still on the road.
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2021 at 8:24pm
Joe, the 8-1/2' was called the "Longhorn". Seems most of the Camper Specials GM built just had 1 ton suspension in a 3/4 ton truck. Must've been an insurance thing. Basically the predecessors to HD written on all the trucks nowadays.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2021 at 8:19am
Not sure what year they started with the camper specials, but I’ve got a 1965 F-250 with the chrome “camper special” tags on the doors. When dad bought it in ‘78 it had a camper, but is long gone now.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2021 at 10:31pm
I have a 2001 f-250 7.3 camper special. 273,000 still runs great, no smoke. has 2 alternators, one for the camper, power plug in the inside of the box, dual batteries( I think standard for diesels) and a fuel line heater. box is starting to show it's age. get people wanting it all the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2021 at 8:52pm
Thanks for the post !! Is there any C/S logo's on the front fender area by any chance ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2021 at 10:32pm
When I bought it used it was only a year old, no indication on the outside of the truck. Was told it was, had 17,000 on it. 2 wheel drive. super cab.
This page was generated in 0.621 seconds.
