A.C. I60 adjusting valves
Dieselherb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Topic: A.C. I60 adjusting valves
    Posted: 07 Nov 2020 at 6:43pm
I'm trying to adjust the valve clearances in the 2.9 diesel engine.There are marks for timing injection pump but I can't find TDC marks
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:57pm
When both rockers are moving on a cylinder adj the valves on the companion cyl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dieselherb Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 7:16am
this is a rebuilt head so not near original setting. can't find TDC only setting from injection pump. Which I think is 22 degress BTDC. I tried adjusting 1235 then turn crank 180 degrees adjust 4678 but 5 was loose enough to fall away from pushrod. then tried 360 degrees then 2 others were loose. Really at a lose!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2020 at 10:19am
Ideally you do each cyl on tdc...both valves closed and "loose". You got to be smart enough to know how to get there.
