A/C HD16DP charging generator source?
hdokes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hdokes Quote  Post ReplyReply Direct Link To This Post Topic: A/C HD16DP charging generator source?
    Posted: 20 hours 40 minutes ago at 4:12pm
Anyone know if a 1966 A/C HD16DP charging generator... even used... can be had? The one on mine has never worked since I have had it and I am just getting around to addressing it. Also... if the specs... i.e. output current and voltage is known that would be greatly appreciated. I know the system is 24 volts but I have to believe the generator output is a bit higher than that. I know there is a regulator involved as well.
Edited by hdokes - 20 hours 37 minutes ago at 4:15pm
