A/C B-112
dmcjt850 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmcjt850 Quote  Post ReplyReply Direct Link To This Post Topic: A/C B-112
    Posted: 21 Dec 2016 at 1:09pm
hello all, i am new to this forum. my son and i were given a B-112 with a mower deck, has been in a barn the last 15 years. everything seems to turn freely, including the mower deck. It has no spark, i picked up points and condenser to try. if that doesnt work i guess i have to pull the motor out and change the coil? it has the hydro lift and all. it is missing the arm rests and the original owner had installed a car radio in the "hood" over the gas tank. a couple mice have mad it their home over the last few years but all in all a pretty clean tractor.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 1:40pm
Make sure the mice haven't chew a wire bare and it grounding out
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 10:19pm
Welcome to the forum.  Tremendous amount  of knowledge on this forum (very little from me, tho!)  Lots of much smarter guys to help out.
Please post a picture or two if you can.  I would also like to get a B-112.  I have a B-110 and a 620.  Horrible, horrible addiction - ONLY KIDDING!!!!  We do like our AC - whether it is farm tractors, or lawn and garden.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:21am
I'll guess the mice have destroyed the wiring. Bet the motor is coming out. Wish someone would give me a $500 mower. Congrats, they are fun machines.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmcjt850 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 6:57am
i have a couple pictures but when i try to upload them they are HUGE. how can i make them fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 12:25pm
Find a picture resizing app or program. I use VSO Image Resizer on my desktop.
AaronSEIA
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 2:53pm
They like to build nest up by coil. Blow it out if you can or remove motor and cover to clean and fix. I would remove carb., disassemble and clean Make sure you clean main jet also!
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:36pm
Heres what they usually look like. You can't clean it out properly unless you remove the engine.
Note the chewed coil wire, pretty common.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmcjt850 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 7:12am
i am starting to think its coming off regardless. if i cant of don't clean the cooling fins on the head it may over heat at some point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 9:57am
That would be best! It doesn't take long! And Littlemarv pictures are great and that small wire is first one chewed up!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmcjt850 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 1:09pm
we dont even have the tractor running yet and i found a pto driven leaf sucker for it on CL. going to work on it tomorrow and see if we can get it to fire off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2016 at 2:48pm
If you pull the engine to clean it take a water hose and wash all the urine out and off it will smell better when you get it started
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmcjt850 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2016 at 9:45pm
So with new points and condenser it started up, however I think we have the throttle linkage installed wrong. I need to get a points cover and we also realized it has the wrong gas tank. I need an inline filter and shut off for the gas. Can anyone offer a little asstance with the hydrolics, I can not get the handle to move at all.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2016 at 5:17am
Hi Doug
Welcome to the Forum.
The B-112 is a great garden tractor. I have an HB-112 with 48" deck still going strong.
Here is a link to a 10 minute Video I used to adjust the Governor on mine.
Good luck
Gary
https://www.youtube.com/watch?v=DjYVKRv612g
Here is a link to a great site with lots of info on Allis / Simplicity Lawn and Garden Tractors
This page was generated in 0.707 seconds.
