A/C B differential/hydraulic fluid
cbt1124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Topic: A/C B differential/hydraulic fluid
    Posted: 29 Oct 2010 at 10:02pm
I have a 1954 model B tractor with a 8 foot snow blade on it. The blade is lifted by the 3 point hitch via a cable and pulleys. I would like to know what fluid I should use in my differential/ hydraulic sump. Also what is the capacity of the sump? Thank You in advance...
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 9:23am
Universal trans/hydraulic fluid seems to work fine in mine.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 3:33pm
B  and  C  Capacity of Trans. and Differential:
No hydraulic - 6 qts.
With hydraulic - 7 qts.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2010 at 5:54pm
Thank you both for the valuable information...
