A/C advice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Topic: A/C advice
    Posted: 14 May 2018 at 7:52pm
Got home from the farm Saturday and turned on the upstairs air conditioner and in a few hours the evaporator coil was a solid sheet of ice so I had to shut it down. And the last few days have set a heat record for this time of year. I have used up all of my R22 and don't want to spend the $$$ to buy a new drum of it so I have got in a call to the heat and air company. This is a 20+ year old heat pump and I have had to recharge it about every other year so I am thinking about biting the bullet and getting a new unit. I can get a $400 rebate from the electric company for a high efficiency unit. Think I should try to get a few more years out of this one or replace it? Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 7:59pm
If you have the area for it go ground source, you will NOT egret it.
Our home is 1800sf main level, about 2/3 that finished lower, heat and cool it with a 7 ton GS Heat Pump. No wells just three five hundred foot laterals 6' under grade.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 8:18pm
Herb, your evaporator probably is leaking. time to replace my friend
I am still confident of this;
Wait for the Lord;
or expansion valve
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 8:52pm
I am thinking it is a very small leak in the evaporator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:07pm
gits down there and sniff around it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2018 at 9:36pm
Yep, Lou got it, get a new one.  They have a sealer, but that usually does more damage than the cure.
