A/C A816
Gordy53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordy53 Quote  Post ReplyReply Direct Link To This Post Topic: A/C A816
    Posted: 05 Feb 2021 at 12:09am
OK I just got my A816 backhoe delivered today after we got it running and yes thanks to previous input from fellow members the fuel shut off is mechanical.
My questions are as follows
1 oil type for engine and trans, diff
2 can we use synthetic oils what grades
3 part numbers/ manufactures  ei oil filters and fuel filters
I plan on a semi restoration new paint decals etc
Thanks
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 6:37am
You might want to post about your 816 on the Construction Equipment Forum.  That where more of the yellow equipment discussions happen.
If you haven't yet, check out the Minnpar website.  They have the 816 parts book on line and they are a source for some parts.  You will find the original filter numbers, most of which can be cross referenced by a parts store.
If you don't have manuals there are several used OEM manuals on eBay right now.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2021 at 3:56pm
For the engine I would use 15W40, forward reverser Dexron ATF, 4 speed 80-90W, diff 80-90W. You can use synthetic of the same viscoscity... just a lot more money, for myself I would probably only do that if living north of 60th parallel and operating a lot in the winter.
The fuel filters are quite common with the Perkins 3 and 4 cyl. If you have a reputable tractor dealer that cover Perkins diesel, they'll get you the right filters. Your engine in that 816 is a Perkins 248 cubic inch. This engine has been widely used in many applications, same filters etc as the 236 cu. in., Massey Ferguson also used these engines. If you're OK with a bit smaller than original oil filter you can use, the famous for many years primarily in the '70's, Ford/Chrysler engine oil filter.
This page was generated in 0.053 seconds.
