A/C 180 has torn hydraulic screen
ClayP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Topic: A/C 180 has torn hydraulic screen
    Posted: 07 Sep 2023 at 7:35pm
A/C 180 has torn hydraulic screen. Can it be repaired or do I have to purchase a new one? Where could I order one? 1967 model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 7:56pm
An AGCO dealership if it is still available. This screen is important and must be in GOOD condition. Anything that gets thru it can lock up the hydraulic pump and possibly break the camshaft in the engine if it does lock up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 8:23pm
Thank you, the hydraulic fluid had a little water in it and I decided to see if it had any sludge in the drain sump. Fairly clean but I noticed the screen was torn away from its frame. Probably should order rubber seals for return and suction tubes??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 8:47pm
I would 50+ yrs old.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 8:57pm
Mine was torn and the screen pulled away from the frame in my D17 IV. Sadly it was no longer available. I used a little engineering and managed to make a new one myself but that might not be for everyone. Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 9:25pm
D-17 IV not the same screen as a 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 9:26pm
My first thought was to repair it. I'm going to a local tractor salvage that has a 180 in it and see if I can purchase the screen if it's good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 9:34pm
But it would be similar in design correct??
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 11:55pm
Screen was available 4 year ago. These are old numbers, will need updated.
#246134 gasket.
#249934 screen.
These are the rubber line seals used on this cover.
#245846 seal
#245847 seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 1:35am
D-17 screen very fine mesh and measures 8" x 8" approximately. 180 is coarser screen and measures 3" x 7" approx. Both do the same thing but vastly different from each other,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 3:26am
Thanks for all the help. I will check out those part#'s to see if they are still available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 3:33am
Are these AGCO part numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 3:48am
Yes, The numbers I listed are from my old AC 180 & 200 parts books, AGCO has updated them but your dealer can cross them easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 6:38am
Ad a 70 to the beginning of each number. They’re still available. Little pricey though
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 6:47am
I just looked in 180 parts book and 70259407 is rubber seal instead of 245847.
Just agco updated number
Edited by Mikez - 08 Sep 2023 at 6:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 6:47am
Thanks again for all the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2023 at 9:21pm
Then my idea of making a new frame and attaching the screen would definitely never work. Thank you for correcting me. Ryan
Edited by Ryan Renko - 08 Sep 2023 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2023 at 10:29am
Thanks for all the help with the hydraulic screen issue. I found a screen locally that was a different style and was able to sandwich the screen between two gaskets and apply permatex to all surfaces. Does anyone know if I can find an oil pressure switch for my A/C 180 at an auto parts store. Part#? Light had been on constantly with good oil pressure. I checked with a glycerin gauge. Thanks in advance. I've named my 180 "Ol Woman ." She shares the same birth year as my wife 1967!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2023 at 1:40pm
Its the same Chevy used for the 350 back in those years
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClayP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2023 at 3:27pm
Thanks Doug!
This page was generated in 0.128 seconds.
