A "BIG AL" Question |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5595 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jan 2022 at 11:44pm |
With a 844 in a semi, how was the air pump run? Was it a gear driven or a belted?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54036 |
Looks like belt driven compressor, off same belt as WP. Scroll down in this old thread, for photos...
ACjack ![]() Silver Level ![]() ![]() Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 275 |
It was belt driven from the fan blade pulley and not from the water pump belt.
We were building engines for both Frightliner and Kenworth. There were minor differences between them and on some of the engines the air compressor was mounted on the LH side instead of the RH side.
I saw just yesterday one of the gen sets with the Mt. Everest 25000 engine. Makes you feel sorry for the 8550 or 4w305 to hold one of the engine blocks up.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8337 |
No kidding there = those things have to weigh close to 5000 lbs ,,
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 603 |
I have one on a AC DES 300 genset. It has a bosch p pump mounted directly on the timing case up high. Its the only one I have seen that didnt have the injection pump low with a drive shaft
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87578 |
I was going from what I saw in Steve's picture, from the old post I linked to. I stand corrected!
