Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 9:29pm
Edited by Lonn - 18 Sep 2018 at 9:36am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 9:51pm
Edited by Lonn - 18 Sep 2018 at 9:33am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 12:06am
looks like damage is all cosmetic
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 4:42am
Not in the 1st picture...Cry
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 6:13am
Edited by Lonn - 18 Sep 2018 at 9:31am
Wink
I am a Russian Bot
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 6:43am
   Do not fool your self with looks
nonetheless ,still dead.
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 8:34am
If the unloader swivel is tweaked, that would be a deal breaker for me.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 9:05am
Looks like the spreader took the biggest hit.  I agree if the pivot is messed up Id back out of it.  Otherwise I would fix it.
I would be looking closely at the shoe to make sure that is ok as well.
Jim
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 9:37am
We can all tell what to do but you have to make up your own mind and live with that. Best of luck to you on what ever you decide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 9:59am
I have a disease which makes me want to fix things.It's a curse.I would fix it.It's all fixable,just have to know what's really damaged.Be a great machine for the money.
They say patience is a virtue......maybe spend a few more years being patient? All our advice is worth what you paid for it.Ask for some guidance from above.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 11:03am
I see the dilemma you are in but anything but perfect alinement of all parts will cause trouble down the line.  I have witnessed several hay balers that have had frame damage they all worked but just would not keep up with undamaged counterparts.
The grain tank and unloading auger would not seem to be the deal breaker if there are new parts available for the pivot,and undamage bins in the junkyards.
I would think if you could undue belts and roll the separator parts by hand you could get a good idea of if shafts are still straight but I have never been around anything newer than a MH2. So no idea of force needed to turn newer machines.
Edited by Ray54 - 17 Sep 2018 at 11:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 11:36am
It's what you CAN'T see that might(will) be a problem. You could say fix it but you need xx hours of actual field operation before you agree it's yours. What I do know is there's a LOT of parts in any combine and they all gotta get along with each other. A minor tweak here, slight bend there and maybe the thing's fine for a day or two but 4 days into the harvest and 'something' let's loose....
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2018 at 8:06am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2018 at 8:10am
Edited by Lonn - 18 Sep 2018 at 7:03pm
Wink
I am a Russian Bot
