99 gmc air conditioning
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 99 gmc air conditioning
    Posted: 08 Aug 2018 at 8:38am
My truck has me baffled. Driving this morning air conditioning was fine. The closer I got to work I noticed it was not blowing cold air. Popped the hood and condenser stuff on firewall and lines were solid ice. What would cause this? Been working fine until this morning.Thanks Tracy
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 8:45am
Sounds typical of developing az leak and low refrigerant.
However I would check the charge.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 9:45am
As Dave said you might have a leak as it appears to be low on refrigerant.  I have to boost mine every couple of years as it as very slow leak.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2018 at 11:39am
my '98 used to do that, I added coolant to the radiator tank that was low and it solved it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2018 at 10:42pm
Cycle switch is stuck closed running the compressor too long. This causes the evaporator to ice up. Low refrigerant levels just don't get cold on a mobile system. It's a simple unscrew and replace. There is a Schrader valve under the switch so recovering the system is not necessary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2018 at 8:49pm
good thought Brian, i have never seen an automotive system ice up like that due to low charge.
This page was generated in 0.293 seconds.
