918H Kohler number location??? |
Orange918H
Joined: 05 Nov 2013 Location: Mound Minnesota Points: 12 |
Topic: 918H Kohler number location???Posted: 02 Jun 2014 at 4:21pm |
Got my heads off the 18hp Kohler Command i had a couple of guys
look at the valve stems for play one said there not that bad the other said to much play i went to a machine shop the dealer told me about in a small town he looked at the exhaust valve play he said one had more play then the other that i should get guides but i'll need the 3 numbers on the engine asked him if the part numbers on the head good enough? he said no well the long and short of it the dealer said the same thing that the numbers might be on a tag or around the flywheel i didn't find either unless the flywheel has to be removed any know the exact location of the numbers? Thanks for any information |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 02 Jun 2014 at 8:53pm |
Look on the shroud that covers the flywheel - somewhere on there should be a tag or stamped numbers .
It ticks me off every time they pull this - you need the numbers - most parts are totally interchangeable - but to buy parts for a engine used in one machine the numbers will send you to a specific dealer - Crank shaft end size is main difference . I replaced a engine in my New Holland with a Kohler General Service engine - but that engine doesnt belong to that tractor - YEP so sell me the parts for a general service engine . Now the tractor has a Honda 18 HP and Kohler is setting in shop along with a second one that came out of same tractor. Edited by Coke-in-MN - 02 Jun 2014 at 8:56pm |
TOMIA
Posted: 03 Jun 2014 at 5:57am |
I have 3 918's and there is a tag on the left hand side of the flywheel cover. It is a stick on tag so maybe yours has come off.
George Jr.
Posted: 03 Jun 2014 at 6:08am |
maybe if you give him your numbers he might luck out
TOMIA
Posted: 04 Jun 2014 at 6:33am |
2 of mine are the same motor and the other one is an overhead cam model.
Model CH 18S Spec # 62513 serial # 2223308257 and 2625712337 Overhead cam model Model CH 18S Spec # 54511 serial # 262310028- not totally readable |
Orange918H
Posted: 07 Jun 2014 at 7:35pm |
Guess i'm lucky i found my Kohler engine information label LOL
all the important numbers can not be read the print is gone - it's useless - a stamped metal tag would of last Thanks for the numbers that were posted by the members i'll check them out Best i can do is click on the link to see the label you can not read http://i203.photobucket.com/albums/aa293/ZZ-IRON/photos%20for%20forums/P6072587.jpg Edited by Orange918H - 07 Jun 2014 at 8:03pm |
George Jr.
Posted: 07 Jun 2014 at 9:38pm |
now because i'm smart and in a good mood i'll give you a lesson when you buy anything that has numbers write them down and file them i understand that old items may have numbers that can't be read when i buy something that has numbers and a manual i write down the numbers in the manual and i also make a copy of the receipt and staple the original receipt and the copy to the manual and put them in the file cabinet i can give any dealer or store any numbers or receipt info they want
Orange918H
Posted: 08 Jun 2014 at 11:42am |
George Jr.
Posted: 09 Jun 2014 at 5:11am |
now write down all the numbers for the ford and file them lol
Orange918H
Posted: 09 Jun 2014 at 3:39pm |
i'll chisel it in stone George Jr. lol |
