917 Hydro Runs but won't move.
Micrometeor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Micrometeor Quote  Post ReplyReply Direct Link To This Post Topic: 917 Hydro Runs but won't move.
    Posted: 16 Aug 2025 at 10:40am
Different battery fixed this. Oops! WAY TO GO ON MY FIRST POST. Engine running fine now but all the Hydro stuff doesn't work. Any issues with the hydro that I should know about?
Edited by Micrometeor - 17 Aug 2025 at 7:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 11:43pm
Welcome to the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 9:51pm
Make sure the belt running the hydro is in good condition and adjusted properly. Owners manual explains the proper set up. Have you checked the oil in the rear? Pipe thread plug on the rear of the tractor. Filter been changed lately? I had an issue one time, it slowed in speed and then stopped. Fluid level was good, installed a new filter and that corrected the problem. If you haven’t changed the fluid and filter I would recommend that first.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 3:07pm
make sure the disconect lever pins are not on or stuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2025 at 8:31pm
Mike that is an excellent point, I forgot to mention the plate on the transmission for the hydro. As Mike pointed it out, there are 2 pins under a spring loaded plate on top of the hydro. When pushed down this allows the tractor to be safely moved in case the engine isn’t running and or the tractor needs repair. By pulling up on the plate it returns the hydro to normal operation. If either of those pins are stuck and not sticking up the hydro will not move the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Micrometeor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 10:20am
I just bought this in this condition basically for the motor.
But the rear pin is stuck in below the big nut so-o-o. If I could fix it I may just put a motor back in it. This is a nice tractor.
I have a snow blower, tiller, and blade, but no mower deck.
So if I can get a movwer deck I'm all set.Does anyone know of one near NÈIowa
Edited by Micrometeor - 22 Aug 2025 at 10:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2025 at 9:19pm
I was given a 917 a few years ago, I already have one but you can’t beat free! Anyway, I soaked those 2 pins with Kroil to loosen them up. The tractor had been sitting outside for a few years. Once I got the engine running the hydro worked fine.
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2025 at 6:58pm
I've got a 42" and a 48" mower deck, I'd sell either but I'm in E. Central Indiana. 765-517-1564
Post Options Post Options   Thanks (0) Thanks(0)   Quote Micrometeor Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 9:29pm
Yes that's a long drive for a possible deck that's in unknown condition. Those are usually the first thing to rust out. If I can get it working good I'll consider it though. Thanks, Just another Mike!!!!
One reason for the Micrometeor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Micrometeor Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 1:46pm
OK I stupidly had taken the stuck pins out and got a little bit of crud that fell in when that was done.
Now the smartest solution will be to remove that unit and look at the possible cleaning or rebuild.
Edited by Micrometeor - 25 Aug 2025 at 2:00pm
This page was generated in 0.299 seconds.
