917 Hydro Runs but won't move.
Micrometeor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Micrometeor Quote  Post ReplyReply Direct Link To This Post Topic: 917 Hydro Runs but won't move.
    Posted: 16 Aug 2025 at 10:40am
Different battery fixed this. Oops! WAY TO GO ON MY FIRST POST. Engine running fine now but all the Hydro stuff doesn't work. Any issues with the hydro that I should know about?
Edited by Micrometeor - 17 Aug 2025 at 7:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 11:43pm
Welcome to the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 12 minutes ago at 9:51pm
Make sure the belt running the hydro is in good condition and adjusted properly. Owners manual explains the proper set up. Have you checked the oil in the rear? Pipe thread plug on the rear of the tractor. Filter been changed lately? I had an issue one time, it slowed in speed and then stopped. Fluid level was good, installed a new filter and that corrected the problem. If you haven’t changed the fluid and filter I would recommend that first.
