917 Hydro Runs but won't move.
Micrometeor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Micrometeor Quote  Post ReplyReply Direct Link To This Post Topic: 917 Hydro Runs but won't move.
    Posted: 16 Aug 2025 at 10:40am
Different battery fixed this. Oops! WAY TO GO ON MY FIRST POST. Engine running fine now but all the Hydro stuff doesn't work. Any issues with the hydro that I should know about?
Edited by Micrometeor - 17 Aug 2025 at 7:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 11:43pm
Welcome to the forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 9:51pm
Make sure the belt running the hydro is in good condition and adjusted properly. Owners manual explains the proper set up. Have you checked the oil in the rear? Pipe thread plug on the rear of the tractor. Filter been changed lately? I had an issue one time, it slowed in speed and then stopped. Fluid level was good, installed a new filter and that corrected the problem. If you haven’t changed the fluid and filter I would recommend that first.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 55 minutes ago at 3:07pm
make sure the disconect lever pins are not on or stuck
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 31 minutes ago at 8:31pm
Mike that is an excellent point, I forgot to mention the plate on the transmission for the hydro. As Mike pointed it out, there are 2 pins under a spring loaded plate on top of the hydro. When pushed down this allows the tractor to be safely moved in case the engine isn’t running and or the tractor needs repair. By pulling up on the plate it returns the hydro to normal operation. If either of those pins are stuck and not sticking up the hydro will not move the tractor.
