917 garden tractor
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: 917 garden tractor
    Posted: 08 Jun 2023 at 3:16pm
 I have a 917 H AC garden tractor.  The charging system stoped working on it.
 When I use it, it's for running a 120/240 generator, so I'm thing of getting a 120 volt A.C. 12 volt D.C. charger to put on it.
  When I am using it, I only run it for 1/2 hour or so.
  Question, what size charger should I get?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2023 at 10:38pm
why not just fix it it probley just the little regulator rectifier
dellrettig View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dellrettig Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 11:14am
I have some inquiries regarding the UK49s Lottery. In this thread, I am addressing these inquiries. The following questions are listed:
1. What is the UK49s lottery?
2. How do I play the UK49s lottery?
3. When and where does the UK49s draw take place?
4. What are the different betting options in the UK49s lottery?
5. What are the prize divisions in the UK49s results lottery?
6. How are the UK49s lottery numbers drawn?
7. Can I play the UK49s lottery online?
8. What are the odds of winning the UK49s lottery?
Tell me below if you know anything about the UK49s Lottery. I'm totally perplexed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 11:42am
    SPAM
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2023 at 9:29pm
Dusty, quite confused on what your trying to do with your tractor? As HUD said, why not fix the issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 1:16pm
 I didn't do anything to try to fix it. The charging system just started working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2023 at 3:11pm
Sounds like it's searchin' for a ground. Clean the Battery ground on the chassis. Also install an aux. ground wire or strap from the blower housing to the Battery chassis ground.
Steve@B&B
