912 does not charge |
Albow44
Topic: 912 does not chargePosted: 11 Dec 2020 at 5:26pm |
I was having this same issue last spring on my 712 Shuttle. I changed the Rectifier and haven't had a problem since.
RLBPA1
Joined: 04 Mar 2012 Location: Somerset PA Points: 286 |
Posted: 02 Sep 2020 at 9:06pm |
Had the same problem with my 912. Turned out to be the ignition switch.
DaveBsACs
Posted: 25 Aug 2020 at 8:20pm |
should be a flat one on the engine shroud, 3 wires all in a row . if still original Kohler. Could be bad connection or wire. Get hold of plug and wiggle, watch gauge while running,have seen corrosion be the problem before.
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 25 Aug 2020 at 5:55pm |
The tractor is 100 miles away and would like to bring parts the next time I go there. I suspect rectifier. What type is used on this tractor? Where is is located?
