8550 repair pictures (She lives!)
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 8550 repair pictures (She lives!)
    Posted: 14 May 2017 at 12:15pm
I have been helping repair an 8550 this past weeks. There were bad gears in the pto dropbox. I wasn't there for the teardown, but it was very time consuming.
Edited by Alex09(WI) - 16 May 2017 at 11:38pm
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 1:25pm
wow...that looks like a mell of a hess!
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:35pm
Ya, what that Shameless Dude said = and I think he has seen it all!   LOL!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 8:42pm
Man, I thought taking my 190 apart was a real job.  That 8550 is huge!  My new motto is:  the bigger it is, the harder it is to fix!
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 9:55pm
Looks like my 7580 last year that was miserable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 10:36pm
Yea any time a skid steer is in the job your doing something good
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2017 at 11:36pm
With a tractor this big, there is quite a bit of stuff to disconnect and remove just to get at the major parts. I am not sure how many man-hours will be in this repair, but im guessing a lot. We should have it going by the end of the week, we are waiting on an oil pump. The first start in 5 years should be quite a sight!
www.awtractor.com
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 11:56am
I thought that dust on the windows looked fairly aged. Good to see another AC kept alive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 11:50pm
We got her fired up today for the first time in 7 years! Torqing the mains and rods took 2 guys! 400 ft lbs on the mains! We'll get her in the fields later this week as we are already 2 weeks behind on our crops :(
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:01am
[TUBE]84aPtUqzwQA[/TUBE]
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 8:19am
it sure sounds good! congrats!
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:28pm
Well done,good on ya for keeping the old girl alive,great to see!,!
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 5:57pm
Wow, that's absolutely impressive. I can see you were some happy.  That's the way to end a long project.   Tim
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:06pm
liked how it started puffin smoke out of one ex. then out of the other ... and then both started smoken and finally she started hitting and caught hold and didn't take long to quit that smoke... and the low rumble with the turbo whine... Man that sounded good. Thumbs Up
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:48pm
That old girl sounded great!!!! Congrats on your hard work!!! Lets see some action in the field!! Ryan
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:50pm
That looks like a long and very big project and I take my hat off to you, but, I want you to do one more thing before you close her up. I want you to pull the valve covers off and run it to check just how much oil is coming out of the rocker arms and down to the valves, adjusting screws, push rods, lifters, and cam. Oil pressure is not oil volume. Our old 4W305 ran @ 65 psi and would not even wet the top of the head after 10 minutes of running in the shop. Pulled the rocker arm shaft and ground a grove from the 4 O'clock hole up to around 3 and 9 to 2 and 10 O'clock. This let the oil out of the shaft and up through the rocker arms.
I know this sounds dumb and no one else on here will agree with me, and I don't care. I have seen it first hand how adjusting screws wear out and push rods turn blue from heat and bend. All caused from a lack of oil volume. When a WC makes more oil volume up top then 4W305, it is a bad day, but a far worse day is coming.
Edited by Unit3 - 18 May 2017 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 10:56pm
That sounds awesome. You have a pit crew too
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2017 at 6:45pm
What blew out of the front turbo?
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 10:08am
WOW!!  You've been busy since I last saw you!  CONGRATS
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 6:26pm
We have had a couple like that, seems they take forever to get back to them sometimes.
Congrats on the first run!!!
Still in use:
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:25pm
Props for keeping it alive and out of the bonepile!
She sounds pretty nasty! The 516 and the 731 and 844 have a startup that will give you goosebumps, that is for sure. :)
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 11:31pm
Wish we had guys like you around here to work on stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 12:22am
It was a day to remember around there. The tractor had been sitting in the same spot in the shed for the past 7 years. The owner David was very happy to get it going (he was cranking in the cab) That day was also the 5 year aniv. of his father's death. He is an all allis farm with his daughter and will be getting it in the field this weekend hopefully!
The shirtless guy on the engine was checking for oil on the rockers which did show up within 60 seconds :) We are currently repairing the top pivot articulating ball which has a lot of vertical slop. It has been raining here so we have not been able to plant or work much ground lately, but we will be chisel plowing with it soon. I will get some pictures for sure!
Yes, those turbo(s) sure do sound good! First grey smoke, then black, then it fired up!
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 8:44am
Looks and sounds great!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2017 at 10:16am
Awesome! Thanks for posting pics & video.
Great startup video!
Sorry to hear of your friend'a loss of loved one. Congrats to their restored AC8550 & their all ALLIS farm.
This page was generated in 0.395 seconds.
