8550 questions |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1314 |
Topic: 8550 questionsPosted: 6 hours 48 minutes ago at 9:43pm |
Good day,
So looking at a 8550 that’s about an hour away that has been sitting for about 6-7 years due to blowing an injection line. Seller says his son finished 10-15 acres of NH3 before replacing the line but says it still didn’t run right so he parked it in the weeds planning on repairing it but never got to it. Seller’s pretty sure it has a hole in the piston? If that’s the case would it be reasonable to only replace that piston and ring set? |
Posted: 6 hours 2 minutes ago at 10:29pm |
Interesting how we go from a leaking injection line (which would leak fuel and could cause a miss-fire) to a hole in a piston ?? Two unrelated problems. It could have been a leaking number one injector line and a failed piston could be number 2 or 3 or 4 or 5 or 6 piston ?? Should have been a ton of blow-by with a failed piston. There are injector lines under the valve covers too.........
Mike Kroupa
Joined: 02 Oct 2009 Location: pierce, ne Points: 339 |
Posted: 5 hours 35 minutes ago at 10:56pm |
I owned and farmed with a 8550 for many years and yes they are notorious for injection line failures. One other possibility is when they replaced the failed line the inj. pump barrel might have moved slightly, causing fuel to bypass and the engine still miss. This happened to me once, removed the one head expecting to find something and everything looked good. Good Luck!
55allis
Posted: 5 hours 30 minutes ago at 11:01pm |
I thought that very interesting too..
Going to look at it possibly Saturday morning if all works out. Seller drained the engine oil last spring or so to start in on the repair so I wont be able spin it over. Is there any concerns about being a dry start? |
Posted: 5 hours 28 minutes ago at 11:03pm |
Fill the new engine oil filters with oil before installing and start it at an idle to let the oil pressure build.
55allis
Posted: 5 hours 18 minutes ago at 11:13pm |
Is there a way to have a custom lines made that has thicker sides walls or bigger line with same fittings?
Never even seen one in person, only photos and videos off the internet so bear with me. With this being told what’s a good price range to offer? Paint is crappy (mostly brown) tires aren’t the greatest but do look like they hold air and might last awhile. Cab interior is crap, seat has a hole. Hour meter reads 3644 hours but not sure if it works. |
55allis
Posted: 5 hours 14 minutes ago at 11:17pm |
Ok, didn’t know what it would do to a sitting engine. Thanks!!! |
