85 912H with K301 Kohler suddenly running terrible
kenora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenora Quote  Post ReplyReply Direct Link To This Post Topic: 85 912H with K301 Kohler suddenly running terrible
    Posted: 28 May 2015 at 3:27pm
I have had the tractor for about 20 years, it has always run well.
I ran it this winter using the snow-blower about 20 hours and was cutting grass for about 2 hours this weekend (at full throttle the grass was wet and high)... when suddenly it began back firing through the carb and won't tolerate any load at all.
I limped back to the garage  and thinking I got a bit of garbage in the carb took it apart and cleaned it. I reset the idle and high speed screws at 2 turns out each but there was no improvement. The fuel is new, the plug is new....
When started from cold it idles nicely for about thirty seconds and then starts to burp and back fire, it can't take the load of moving without bucking and sounding awful.
I have done what I can....any ideas?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenora Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2015 at 4:14pm
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 12:32am
When was the last time that you changed the points and condensor?
Or, the flywheel key is sheared ever so slightly to throw the timing off.
That's the first thing that comes to my mind. Checking those things. HTH. Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 6:17am
Hmmmmm.... fuel is new. Possibly a bad batch of fuel sounds like to me to all of a sudden run lousy. I would drain the tank, and add fuel from another can or source and then give it a whirl again. Make sure you drain the carburetor. Couldn't hurt to add a dash of dry gas to it also just in case you got the bottom of some gas stations tanks... HTH
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 8:53am
replace the points and condesor change out the gas
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenora Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 12:51pm
Thanks for the advise...the gas is changed already and I'll hunt down points and condenser....I priced the coil locally and it was $368.00 plus tax...OMG...I never priced the points and condenser cause I was on the floor!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenora Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 1:33pm
Found them on EBay for $37.00 Cdn shipped to my door...the local dealer wanted $60 plus tax...
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2015 at 6:42pm
wrong info there points4715003s napa store 12.00$  condensor230722 6.00% napa  coil231281napa30.00$ hope  this help all oem #s cross to napa parts
This page was generated in 0.297 seconds.
