840 wheel loader
53 ca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53 ca Quote  Post ReplyReply Direct Link To This Post Topic: 840 wheel loader
    Posted: 23 May 2021 at 3:53pm
have a 840 b wheel loader that we changed motor and hydraulic pump on. Also changed transmission fluid. Now it will not pull itself up any grade until it gets warmed up. say about 10 to 15 mins of run time.
 what fluid should I have used in it ?
 THANKS for any info. Jerry
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 6:37am
Jerry:  the information on the hydraulic fluid should be covered in the 840 Articulated Loader Operators Manual Form SV-112B - Part No 1012879-1.  Unfortunately, I don't have that in doc. in my periodical library.
If the fluid is not the problem, it might be good to start with a clutch pressure check or could be also worn splines on the Torque Converter Pump drive, flex drive plate failure or low  clutch pressure which would occur as a result of a weak regulator valve spring or regulator spool sticking.   The later could be remedied through removal and cleaning possibly.
The Service Manual for the AC 840 wheel loader is form No. ISM-17 and part number 1013042-5.
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 9:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53 ca Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 8:29pm
pretty sure it is good. Just for the info how do you check the fluid level? I was told to use Dextron ATF . Right or wrong??
 I will check fluid when I get by the loader this week.
 Thanks, Jerry
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 10:08pm
reply #25 says there should be TWO marks... running, and motor off ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53 ca Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 6:56pm
Thanks for the info, When I get back to the loader I will do some more checks and see where things are. Where can I get a service manual for it?
 Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 8:17pm
e-bay.............. not cheap
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 2:48am
Not expensive compared to what might happen without though
This page was generated in 0.730 seconds.
