840 wheel loader need parts
Mrcarcrap View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrcarcrap Quote  Post ReplyReply Direct Link To This Post Topic: 840 wheel loader need parts
    Posted: 02 Feb 2018 at 10:24am
Hello everyone I'm new and need help.
I'm working on an Allis Chalmers 840 wheel loader.
Model number on the vin plate is 1095175
Serial number 2328
In the cab.. I'm looking for the forward reverse shift lever/handle assembly.
AND the part that it goes into.
I'm being told the part name for that assembly is called shift pivot shaft.
The forward/reverse handle comes completely out of that box and has (had) splines on it..
So I'm assuming the box (shift pivot shaft) should have some type of gear in there.
I see Nothing.
The problem is it is in low gear ALL the time.
I have been given part numbers for each but cannot find either item.
Help I'm stuck in slow motion over here
Cannoncollector View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cannoncollector Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2025 at 7:41am
I need a shifter handle and tooth slider also.. someone should repop a batch.
