84 gleaner n6 feeder house
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: 84 gleaner n6 feeder house
    Posted: 14 Nov 2024 at 6:53am
When i speed the feeder house/header up it has a good amount of howling noise, when I slow it down it goes away. But at the speed I run at I need the feeder house/header at the speed that makes the annoying howling noise. Is there a fix for this noise or no? I do not notice any bearing s that have gone
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:11am
On the RH side down low, which pulley speed are you using ?? Large (fast) or small (slow) ??   Slow down the VS corn head drive and with the engine off spred apart the lower sheaves with a bar. Disconnect the corn head drive shaft and see if you can move that throat countershaft up/down or forwards/backwards. That bearing could be spinning on the shaft.
Edited by DrAllis - 14 Nov 2024 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:07pm
Hey dr.allis. I did as the book tells me. Unless you have different ideas. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:08pm
Maybe bearings inside the upper or lower drums are shot. ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:29pm
If the right side has the belt on the small sheaves, you'd better be checking that bearing on the left side as I have described. Also, the upper variable sheaves have bearings that need to be repacked with grease every couple of years. Maybe they are dry and failing. I'd think if you had feed drum bearing problems you'd be experiencing chain issues not a howling noise. Disconnect the corn head and see if the noise is still there or not with the drive fully sped up.
Edited by DrAllis - 14 Nov 2024 at 8:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2024 at 4:17am
I will check that this weekend doc. Thanks
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2024 at 6:21pm
I would second bearings on the variable sheaves. Go step by step. First as described disconnect head and try. Next remove chain from the reverser and try again. If noise persists remove the belt from the rear feeder chain and try again to see if the noise goes away, if not remove belts from the front chain and try again. If it still howls it has to be bearings on the front shaft that the header hooks up to or the bearings in the top variable assembly. You could remove the variable speed belt to eliminate the front shaft but you should be able to tell where the noise is coming from by that point.
This page was generated in 0.071 seconds.
