82S mower
Wolverine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wolverine Quote  Post ReplyReply Direct Link To This Post Topic: 82S mower
    Posted: 05 Aug 2023 at 9:37pm
Buying a 82S mower that is on a D14 I am putting it on a D17 is it the same mount?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:46pm
Yes it uses the same mounts. Only thing you will need is a longer brace that goes from the rear pto drive support to the final drive. Easily made at a good machine shop. I had to have one made for my D17, as the one for the WD is too short.
Excellent mower in so many ways, best design from AC in my opinion.
Edited by AC720Man - 05 Aug 2023 at 10:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2023 at 9:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wolverine Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2023 at 9:32am
Thanks for the info haven't picked it up yet maybe they have the other support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2023 at 12:38pm
That would be great if they have it. But it is an easy piece to replicate. I just placed the bracket on the drive support and took some measurements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2023 at 12:49pm
Since it is coming off a D14 you will not use the frame spacer on your D17. It is required for the D14 due to having a narrower side frame width. Just use the anchor bar. The operating instruction/setting-up directions &parts illustration book is excellent. Hope the mower comes with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2023 at 12:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wolverine Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2023 at 5:26am
I have a book ordered for it.
This page was generated in 0.045 seconds.
