816-Backhoe Filters
Gavineg123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavineg123 Quote  Post ReplyReply Direct Link To This Post Topic: 816-Backhoe Filters
    Posted: 29 Jan 2021 at 6:06pm
I just bought a AC 816 backhoe and am curious if anyone has the fuel filter, oil filter and transmission filter sizes? The filters in it currently have no writing
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 8:04pm
Is a site called baldwinfiltersrus.com
Company is Application Associates, has a decent site to look up by application then take the baldwin filters to you local source see if they can cross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gavineg123 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 10:18am
Man that was perfect! Thank you so much, I ordered all the filters after getting the numbers from them.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 1:33pm
Were you able to see pictures of the filters you ordered, most easily noticeable would be the fuel filters? It's happened more than once that Baldwin has come up with wrong numbers for me. I never bought Baldwin for my 816 but for my Cat as well as Case backhoe they've been wrong on oil and fuel filters. For your Perkins in your 816, if you're willing to use the common older style Ford/Chrysler oil filter it fits. The original has the same base but bigger volume. Your forward reverser has plugs, at the lower front and back, one has a screen that needs to be flushed clean. The torque converter also has a plug for draining. Have fun with your 816 Smile
